In order to get an idea of a GPU's power draw when gaming, we record peak system power consumption during a 15-minute run of Battlefield 1 at 3,840 x 2,160 using Ultra settings. We use a watt meter to measure the three instances of peak system power draw (every five minutes), and we also take an idle reading at the Windows desktop (3,840 x 2,160).
Thermal output is measured using the same Battlefield 1 stress test as above. The GPU is installed in a closed but fairly well ventilated case (Corsair Carbide Series Air 740). We leave all GPU fan profiles and settings as they come and leave the game running for 15 minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z or equivalent and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
